Baffles
You state:
"I have 3.25” od slip ons that have no baffles. It sounds like machine gun fire when the engine is under load."
That is rather unusual..
Backfires and such general happen when throttle is closed.
Under load would be when you are opening the throttle or pulling down the road while applying throttle.
From the picture it looks like perhaps you have aftermarket slip-on mufflers.
Any brand markings on the slip-on mufflers?
What does the inside of muffler look like from the outlet?
If you are unable to locate any branding then perhaps J & P cycle for baffles..
Sometimes a simple lollipop in the mufflers is cheap, adjustable and effective if some back pressure is required.
Yes, it does backfire some on roll off but it really makes a loud staccato when rolling on the throttle.
I don’t find any markings on them except a disclaimer stamped into it about not being DOT approved and not legal for street use.
They are completely open all the way to the inlet and I don’t see any evidence of any kind of mounting hardware for any type of insert.
They very closely resemble Full Boars but most FBs that I’ve found are either 3 or 3.5” od and mine are 3.25”.
