Cracked stock head-pipe TC-88
During installation of my new tires, my indie mechanic pointed out that my stock head-pipe on my 2003 FLHCTI has a cracked rear head-pipe at the Y-connection. The recommendation is to replace it with a Cobra true dual unit since stick items are unavailable. I’m leaning towards the Cobra pipe recommendation and now I’m wondering about a good tune. Since this is an old ‘03 Twin Cam 88 with no O2 sensors I’m trying to figure out how a tuner will actually help.
Will the new head-pipe require modifications to accommodate any O2 sensors for ECM/ECU feedback? Has anyone been down this road and have feedback I can use? Thanks all in advance for your input.
The following 3 users liked this post by I Like Pie:
The 2 I fooled with in the past we tack welded the crack, then removed pipe and welded it up.
One we did make a gusset for it.
If /When you order the pipe just be sure to note info about bike and if it comes with O2 bungs you can get plugs for them
WP
WP
The following 2 users liked this post by WP50:
eighteight (08-10-2023),
OkieBill (08-09-2023)
Unless of course you want a tru-dual type set up.
Besides your bike doesnt have 02 sensors now and should you go the tuning route a tuning shop will be able to install temp bungs and plug later.
OkieBill (08-18-2023)
