Very mild decel popping with Fuelpak
Just did the Stage I with Rinerhart slip-ons, Fuelpak and hi-flo. Bike runs great. I am getting a little decel popping at around 20-30 mph. It is mild and not loud popping or backfiring. I checked the muffler clamps and they are fine. I used permatex copper when installing the slip-ons as well. Is this anything I should worry about??? Should I call V&H and see if they have any suggestions on setting changes?? Or should I leave well enough alone??? It isn't like it bothers me or anything.
RE: Very mild decel popping with Fuelpak
Actually I went ahead and gave them a call. They said change "Mode 23" to 15. I did a little searching on the "Mode 23" and some people have been told to change it to 15 and others to 50. I guess if the 15 doesn't work I'll try the 50. If that doesn't I'll put it back to 16 and deal with it.
Make sure there are no exhaust leaks. If you RE-USE any of the existing muffler clamps, you run the risk of air leakage, causing the back-firing on deceleration. The clamps are not designed to be re-useable. It happened to me. Try replacing your muffler clamps, check all connections for a good seal. Muffler clamps are a cheap fix. After that, you will need to probably re-tune which ever fuel management unit you are using.
