2006 Electra Glide Classic Mufflers
RE: 2006 Electra Glide Classic Mufflers
ORIGINAL: ClassicRide
Want to add those touring mufflers but dealer says you need to bring it back in for the remapping,,, he told me the price and I almost fell over,,, said something about a air filter too
If your only going to install the Catalyst touring mufflers PN 80463-06 you shouldn't need to do anything. I think your dealer is not understanding what you want. The air cleaner and map is for Stage 1 heck for the 06 bikes Stage 1 is only the air cleaner and map, you don't need either to install the catalyst touring mufflers. Now if you was to install SE Pro mufflers or one of the many non catalyst performance mufflers then you might run a chance of the engine becoming lean.
Not sure about the sound of those, my guess is they will be just a touch louder than stock. I had a set on my 05 EG Classic for a few hundered miles before I did the Stage 2 to it. On my 06 Ultra I have the SE Pro mufflers and the stage 1 air filter and the SERT to map it with.
ORIGINAL: rkoko164
To anyone who has removed a set of catalyst mufflers:
Is the cat only in the right pipe? You can tell by looking in the inlet.
