anyone wrap there pipes??
foundationapps (06-29-2021)
ultraglide12 (07-02-2021)
I'm not saying that you shouldn't use header wrap. Just understand you can cause problems with the integrity of the pipe. I had a set of Vance and Hines short shots on my Dyna at one point and one of the pipes was wrapped under the heat shield to keep heat off the legs. That pipe eventually cracked presumably due to heat held in by the wrap and moisture being held in possibly as well. Again, not saying don't do it. Just understand that you could crack a pipe and so be be ready to address that should it happen.
