Mikuni 45 Choke
Old 08-04-2007 | 12:16 PM
SaltySteve's Avatar
SaltySteve
Default Mikuni 45 Choke
I have a ? about The choke. Does the Mikuni work like the Harley carb? (Out-Half in- Shut). Or is it Out and In?
Help.....
Old 08-05-2007 | 03:17 PM
chopper.stud's Avatar
chopper.stud
Default RE: Mikuni 45 Choke
I have the same carb. You should be able to pull it allthe way out, then push it half way in to lower the rpm as it ewarms up, then push it all the way in to close it. There should be just a little play in the cable at the choke **** before you can pull it out. If not, the choke can be sticking open...it can be adjusted at the cable adjuster on the choke cable near the carb. Dont know if this answers you question?
dkfxr
EVO
03-09-2013 03:18 PM
Collk88
11-15-2012 08:50 AM
jbubbalee
07-28-2012 08:42 PM
WadsChopShop
06-17-2010 09:49 PM
ngf74
03-22-2007 12:38 AM
