Choke broke
Old 07-28-2007 | 05:45 PM
Deuced512's Avatar
Deuced512
Default Choke broke
Got a question - my choke wasn't staying open and I just checked it out to find the plastic part is cracked. It looks like I need to replace the whole cable, but I can't tell. Anyone ever have that happen before? Any idea how to fix it - or what it costs?
Appreciate the help.
Ed
Old 07-28-2007 | 06:40 PM
wesd41's Avatar
wesd41
Default RE: Choke broke
The entire cable assembly runs about 20 bucks. I just bought one for my bike.
Old 07-28-2007 | 07:33 PM
Deuced512's Avatar
Deuced512
Cool - that's not too bad. I have an 01 Deuce. What's it take to put it in?
Old 07-28-2007 | 08:09 PM
wesd41's Avatar
wesd41
removing the choke assy from the carb, removing the old cable from the plunger and installing the new cable, then reinstalling the choke assy on the carb.
And you'll have to remove the air cleaner assy and carb, too, BTW.
Old 07-29-2007 | 01:40 AM
Deuced512's Avatar
Deuced512
I got it. BTW - did you have to remove the fuel lineor the throttle cables from the carb or could you get to the choke cable with those on there? I took a look at the carb and then the manual - from what I can see it looks like the throttle cables may be ok to leave on - but I don't know about the fuel line.
Old 07-29-2007 | 02:08 AM
kansasroadking's Avatar
kansasroadking
you'll have to take the fuel line off, not enough slack. be sure to close the petcock......
Old 07-31-2007 | 07:11 PM
Deuced512's Avatar
Deuced512
Hey thanks again guys - finally got the part and finished up the job today. Like you said it was pretty easy - I never had to take the throttle off - but the fuel line had to come off. The bike runs a lot better now that the cable works right - I think it might have been leaving the valve open before.Damn I guess I should check the plugs...
Old 07-31-2007 | 10:50 PM
shortfatboy's Avatar
shortfatboy
just be careful not to overtighten the lock nut on the other side of the bracket...thats what breaks them
Old 08-01-2007 | 04:02 PM
Neckball's Avatar
Neckball
Yep, that will do it (don't ask me how I know.............)
bharvey60
04-17-2012 10:49 AM
patsfan05488
03-28-2011 09:27 PM
WadsChopShop
06-17-2010 09:49 PM
Classic Eagle
Carburetor Related
08-31-2009 09:28 PM
ngf74
03-22-2007 12:38 AM
Quick Reply: Choke broke
