Rinehart True Duals Chirp or high pitched rattle
Old 07-24-2007, 08:03 AM
tduff's Avatar
tduff
tduff is offline
Default Rinehart True Duals Chirp or high pitched rattle
I know there have been many posts on this topic, but I am curious if anyone has actually fixed this problem. So, if your setup had this issue and you were able to fix it, post up and let us know what you did for a cure. I would also like to know if any of you complained to BUB and what their response was or if they offered you a solution.
Old 07-24-2007, 08:33 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
Default RE: Rinehart True Duals Chirp or high pitched rattle
Remove the baffle and spread out the end closest to the head pipe.... There is not enough interference between the muffler housing and baffle.... Need to tighten up the fit...
Happens sometimes....
Old 07-25-2007, 03:27 PM
molsen's Avatar
molsen
molsen is offline
Could be that a heat sheild or the bracket by the starter came loose. On mine I had the rubber hanger by the saddle bag have movement. Quick fix was a body shim to take the sound out.
05HDR
03-25-2009 09:24 AM
phillaf65
10-13-2008 12:33 PM
NATESBPD
08-03-2008 12:00 PM
fd2430
10-16-2007 03:06 PM
swampking
08-10-2007 06:43 PM
Quick Reply: Rinehart True Duals Chirp or high pitched rattle
