'05 Fatboy vacuum operated fuel valve
Hey Gang,
I took the fuel hose off my carb to do some work on it and left the vacuum operated fuel valve in the on position and fuel continualy ran out of the fuel hose (engine off of course) until I turned the valve off. I thought that the fuel is only supposed to flow with the valve in the on position and vacuum being applied by cranking or a running engine. Am I wrong? If it is defective (out of warrantee) is there a recall?
