Swapping exhaust 2010 Street Glide
I bought a 2010 Street Glide with Screaming Eagle exhaust pictured. The bike had a Stage III SE upgrade when purchased new. I'd like to trade out the 2 into 1 header system for a 2 into 2 exhaust system. Will I need to retune the bike for an exhaust swap?
Received 6,055 Likes
Thanks Kel, I just like the balanced look and sound of a 2 into 2. And this one is a little loud for me. Hoping to trade it out with someone that likes the 2 into 1. You're the 2nd one that's told me changing the exhaust probably won't call for a retune. Trying to avoid that $$ trip to the dealership. I like the looks of your 2010 Ultra. Have you ever thought about trading up to a newer bike for the stereo/GPS system?
thanks again,
Rat
thanks again,
Rat
thanks again,
Rat
thanks again,
Rat
I will be the exception and state that changing the exhaust will definitely have a large impact on the tune. Can you get by with not retuning? Sure. But don’t you want it to run it’s best? I’ve been tuning bikes for many years and I can assure you that I’ve never seen someone go from a 2 into 1 exhaust to a true dual and not benefit greatly from a retune. Now, if your dealership doesn’t have an experienced tuner, don’t go there. Find someone with real experience in tuning— it will be money well spent.
I would have the bike tuned for the new exhaust if you want it to run its best. I could be wrong but I would bet the new tune will require pulling some fuel out as the true duals will flow a bit less without the jugs working together to pull the exhaust gasses out. As mentioned, I could be wrong but I am sure I will be corrected by someone more in the know...
rattracer76 (10-14-2019)
