Stage 1 Question
RE: Stage 1 Question
The stage one flash is calibrated for HD parts but will be close for the pipe install (but still lean). My .02 is to go with the DFO anyway. It will run much better then because of the lean settings in the stage one flash.
Normally the stage one download would cover the exhaust also
I have an ’07 FLHR with SE II mufflers and would like to installed my newly purchased AN BS stage 1 air kit. Since I’ve got an opportunity to get a free download (due to bulletin), what curve would you recommend I request to compliment the air kit and help keep my ride AFR in check?
Thanks,
Em …
Thanks,
Em …
ORIGINAL: Em45
Thanks,
Em …
Thanks,
Em …
I don't recommend the stage 1 download as it will still be too lean in my opinion.
