If I remove the bolts on this exhaust hanger, is fluid going to spill out?
The arrows point to the bolts in question. I want to put on another exhaust that came with the bike to compare the difference.
The other exhaust doesn't use this hanger and also this hanger would get in the way so I have to remove it.
If the highlighted bolts are holding in fluid then I'd like to know the length, diameter, and threading pitch of bolts I can buy since I would't be able to reuse the existing ones since I assume they're too long.
The exhaust is a Martin Bros Medusta and this is on an 04 Ridgeback.
Anyone know about these bolts?
Do you know how I would check the fluid level in that tranny and what replacement fluid to use?
