Torque cones: Help or hurt performance?
Old 06-30-2007, 03:45 PM
bs883's Avatar
bs883
bs883 is offline
Default Torque cones: Help or hurt performance?
Maybe I'm kicking a dead horse here, but I've got some questions about torque cones. I know these are suppose to increase backpressure, creating more torque from wide open pipes such as drag pipes. I've done some research online, and I've read that these are a waste of money. Any thoughts? Personal experiences?
Old 06-30-2007, 04:09 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Default RE: Torque cones: Help or hurt performance?
The are a restriction and the worst thing to install in your exhaust system
Old 06-30-2007, 09:53 PM
Dalton's Avatar
Dalton
Dalton is offline
They are a POS and do nothing but hurt performance. If you need a little back pressure, try the "lolli-pop" baffle, a washer welded onto a bolt, installed in a hole you drill in the underside of the pipe. Better than nothing, but drag pipes are a real problem, have all kinds of dips and spikes in the torque curve.
Old 07-01-2007, 11:48 AM
bs883's Avatar
bs883
bs883 is offline
Thanks for clearing that up guys. The drags came on my bike when I bought it, and they may have to stay on the rest of the season. What would you suggest as some nice, economical pipes for my '01 883C?
Old 07-01-2007, 11:52 AM
jimmyz's Avatar
jimmyz
jimmyz is offline
installed torqe cones on my rk after installing true duals. I've run both ways and they do help my low end power. Run them on my 1200 sporty as well with the shogun pipes. JimmyZ
Old 07-01-2007, 07:06 PM
bs883's Avatar
bs883
bs883 is offline
How about something like Big City Thunder baffles? Anyone have experience with them?
Old 07-02-2007, 12:37 AM
str8pipe's Avatar
str8pipe
str8pipe is offline
put in a baffle. the torque cone are a restriction i would never use. i would probably go with the big city baffles.
Old 07-03-2007, 09:34 AM
ReeseSS's Avatar
ReeseSS
ReeseSS is offline
I am thinking people missed the part about" drag pipes." On drag pipes, the cones will increase the exhaust velocity that was lost, and improve the scavenging at lower rpms that was also lost. (low exhaust velocity and poor scavenging produce a lot of inversion in the lower rpm range and sucks exhaust back into the chamber during the valve overlap period, diluting the A/F mixture on the intake stroke). Drag pipes are only beneficial at high rpm's, the cones will improve your low end on drag pipes but it is still not a very efficient system for normal street use. 2 into 1 and cross over (power port) systems perform well because the exhaust pulse from one cylinder can fill in the gaps of the other cylinder's pulse, keeping the gases flowing, increasing the velocity and improving the scavenging affect which also reduces inversion. Good scavenging helps "pull in" the fresh A/F mixture.
Old 07-03-2007, 10:34 PM
Littleshack's Avatar
Littleshack
Littleshack is offline
Use them with a stock motor. Do Not use them on a Modified Motor.
Old 07-04-2007, 08:19 AM
Velocity1's Avatar
Velocity1
Velocity1 is offline
Torque cones do have their practical applications. They're by no means the ultimate exhaust performance mod, however they made my stock TC88" Softail with a baffless SE Pro Pipe scream low end.
Let's just say they have their applications, but are notthe advertised or endorsed cheaper "cure all" they are often mistaken for.
V1
Quick Reply: Torque cones: Help or hurt performance?
