2008 FLHR V&H 2 into 1 does not have O2 sensor holes?
I picked up a used Vance and Hines Pro Pipe for my 2008 Roadking but it does not have holes for the O2 sensors. Did I goof up? The intructions just says for 07-08 models uses a different mounting bracket but nothing about the O2 sensors.. Thanks in advance.
Smells like B.S. If they intended that the pipes had to be used with the tuner they want to up sell you, it should be stated on the website with the product description. Not a very ethical business practice.
If it was me, I would be pissed and get my money back, then buy another system that's set up for that bike. There's quality alternatives out there and most cost less than V&H, leaving you some cushion if you decided later you wanted a tuner.
Actually Vance and Hines Pro pipes on their website says that Oxygen sensor bung plugs are required for 05-06 models which would indicate if they were for your 08, they would have 02 bungs.
https://products.vanceandhines.com/store/harley/17557/
It looks like the pipes I bought were produced before 2008. They do not have o2 sensor holes. The newer pipes have the holes regardless of year and plugs available for models without o2 sensors. Now I either have to get a fuel pak and eliminate the o2 sensors or weld in bungs to put sensors in the pipes.
