Rinehart True Duals mounting bracket
I am installing a set of Rinehart True Duals on a 2007 Ultra Classic. According to the installation instructions the old mounting bracket attached to the starter motor is replaced with a Rinehart bracket. According to the picture in the instructions the hole for attaching the exhaust clamp faces toward the rear cylinder. This will not physically fit in this configuration. If I turn it around, opposite of what the instructions show, the bracket fits perfectly. However, when the exhaust is installed there is only about a 1/16th inch clearance between the bracket and the exhaust header. Will this be an issue? Do I have the wrong bracket?
Thanks,
Rick
Thanks,
Rick
