8 deg injectors or 25 deg injectors
07-25-2018 | 08:57 AM
I have owned my 06 FLHRSI Road King Custom for 8 months. How do I know if the change was made between the 8 and 25 deg injectors?
07-25-2018 | 01:26 PM
Might be in the dealer service network data base. Ask your dealer if they can look it up for you.
Other than that, take one out and look at it.
08-05-2018 | 08:21 PM
Look from the front left side of the bike at the rear injector. There should be a part number there. The 8 degree # is 27625-06....I can’t remember the 25 degree part number.
Reason: Clarification
10-14-2018 | 04:33 PM
they also say 25 deg on them
10-15-2018 | 10:17 PM
If it has the 8s and you install the 25s do not get it reflashed for the 25s. The map for the 8s averages about .2-.3 of an air fuel point richer which the bike will love.
Just out of curiosity - are you having a problem?
Also - here is a link to the information on identifying them as well as the pdf attached.
https://www.rbracing-rsr.com/downloa...jectorswap.pdf
11-04-2018 | 07:57 AM
Moved question to the Injection section
Johneb48
05-24-2011 05:08 PM
NCCopBikeRider
10-28-2007 07:29 PM
1of2
06-29-2007 02:02 PM
tooch69
11-28-2006 11:10 PM
heavy hauler
07-21-2006 02:11 PM
