stock pipe modify
stock pipe modify
has any one out there ever tried welding a plug or restrictor in the rear crossover pipe on a '05 bagger? or can you see any problems doing so. i would like to retain the stock appearance yet try to get a more even flow through each muffler without using the tru duels. at the same time i'm going to the SE slip-ons,SE air filter and the power cammander. this is on a '05 electra glide that is factory stock and runs and starts flawlessly so i am a little nervous in fixing something that doesn"t need fixing .
RE: stock pipe modify
WHOA cowboy,.... no need to put a restiction in the stock pipe they work just fine with se II slip ons. not to mention no real way to do that without making the chome look VERY bad after you weld in the pipe. You are on the right track there with you parts list so far that is, stay away from the true duals they are not your freind when it comes to a 88inch bike that is stock unless you are looking to give up some of your bottom end tq
