Chain drive cam change
5 million post on gear drive but chain is few and far between! Fixing to do a cam change on a bike from 26A to 211. He has roughly 10:1 comp. Hear is parts list so far: Outer and inner chain tenshioners, 2 tenshioners retaining rings, chain guide, sprocket spacer kit, 211 cams, exhaust gaskets, Fueling rebuild kit (for Fueling oil pump), cam instulation kit, 2 Temkin B-148 bearings. I will need new o rings for the adj. push rods, cam cover gasket, lifter cover gaskets, thrush washer/inner race with o ring.Are these mentioned in before sentence included in the instulation kit or do I need to order some of it seperate? Anything I forgot? I have done gear drive cams but putting a chain drive back in is new. Any potential pit falls to watch out for is also appreciated. I have looked at HARLEY HOG site and A members of this sights web pages but can never have to much info. Thanks
RE: Chain drive cam change
try here http://www.harleyhog.co.uk/tensionerinstall2.htmand here http://www.nightrider.com/biketech/hdcaminstall.htm. Doing onealso thisweekend
Road Star
Engine Mechanical Topics
19
09-12-2014 05:04 PM
