Carb misfire at low RPM
RE: Carb misfire at low RPM
ORIGINAL: Doc 1
...Now on you Mikuni the screw is in front correct....so going in with the screw will cut off the air so it willlean the mixture and vice versa...
When you say it like that, Doc, it seems to make sense. I did...I've studied that tuning guide quite a bit and it's not clear as to "too rich" or "too lean" in the air screw department.
It says if you get the best idle at one turn or less that you need a larger pilot jet, and if the idle isn't affected by going out to 3.5 turns (I think) that you need a smaller pilot jet.
Stanley_Wilson
Carburetor Related
09-25-2014 12:25 PM
