Sealing Rush slip-ons
Old 05-27-2007, 07:45 PM
Cruiser 1970's Avatar
Cruiser 1970
Cruiser 1970 is offline
Default Sealing Rush slip-ons
While changing the baffles in my Rush slip-ons, I looked down into the muffler and could see daylight where the muffler attaches to the main pipe. I had read other post suggesting sealing the connection using a high temperature RTV silicone called Ultra Copper.
Well I finally got around to sealing my pipes yesterday and wow what a difference it made. The sound is a lot deeper and throatier. The bike is just a lot more fun to ride. It made enough difference that if you haven't sealed your pipes; I think you will be pleasantly surprised at the difference it makes.
Old 05-28-2007, 07:59 PM
TerryM's Avatar
TerryM
TerryM is offline
Default RE: Sealing Rush slip-ons
I am about to switch my wild pigs to rush. Where do you find this sealer and how do you do it?
Old 05-28-2007, 08:47 PM
Cruiser 1970
I bought mine at Auto Zone, but you should be able to find it at any auto parts store. As far as the application, I ran a bead around the inside edge of the muffler and slipped it on to the pipe from the engine and then tightened the clamp. You can look into the muffler with the baffle removed and see if you have a good seal.
Old 05-29-2007, 09:09 PM
Soft06's Avatar
Soft06
Soft06 is offline
[sm=exactly.gif]And buy NEW clamps also....
Old 05-29-2007, 11:26 PM
Tommy Meisel's Avatar
Tommy Meisel
Tommy Meisel is offline
Amen on the new clamps! You can reuse the old clamps, but they do not grip and squeeze like new ones. Get new ones, and get a long wrench to tighten them with, because the nut is hard to turn on the new clamps until the clamp reaches the end of its travel. With a short wrench, you might think they are tight but they are not. I think mine were about 8 bucks apiece at the dealer.
Old 06-01-2007, 05:02 PM
bear211's Avatar
bear211
bear211 is offline
I have a 2007 Street glide with Rush slip on's. Is the reason you sealed them because of decel pop?
Old 06-01-2007, 05:33 PM
JeffSG's Avatar
JeffSG
JeffSG is offline
Be very careful using a sealer on the '07s. If it gets inside your pipes it will play havoc with your 02 sensors.
Try the new clamps first...that was all I needed.
Peace,
Old 06-02-2007, 12:30 AM
mcouture's Avatar
mcouture
mcouture is offline
The RTV sealer I got said "sensor safe" right on the package.
I can't believe the difference it made in the sound on my bike!
Wisenheimer16
09-30-2016 01:28 PM
iwillfixthem4u
12-11-2011 06:13 PM
jrr
10-04-2010 04:21 PM
robertj74
01-09-2008 08:54 PM
Cruiser 1970
04-30-2007 02:59 AM
Quick Reply: Sealing Rush slip-ons
