Remove packing leave baffles in Cobra slip ons?
chuckwitdatruck (01-23-2021)
I know this is an old thread but I hope others will respond if anyone else has since this was first posted. I did remove the packing from my Cobra slip ons and left the baffles in. Sounds much better. No change in performance. Will I run into problems later? Will my chrome start bluing? As of right now I love it and don’t plan on putting the packing back in.
The following 2 users liked this post by slw210:
Aluminum13 (01-08-2023),
chuckwitdatruck (02-28-2021)
all you will do is change tone, there will be no increase in power although the BUTT dyno says so.
that baffle is a flow through perf. when a pressure wave flows from the head into the baffle, some of the wave passes through the baffle holes, reflect off the outer tube back into the main stream cancelling 180* out of phase wave. by adding resistance aka the packing, the tone is controlled.
Yeah I love the sound and I definitely agree with the possible butt dyno. Im 100% happy. Im just more so worried about it bluing later. Im not the type to spend money and want to spend it again because of either a mistake, unhappy with something or just because a newer better version of something came out because the masses like it. I stick with whatever decisions I’ve made but.. it cant become cosmetically tacky or not performing as it should.
