Hi, have to take the tank off my '99 Road King Classic. The manual says to remove the fuse for the fuel pump - but I don't seem to have one! The block has 4 and none of the wiring seems to match to that for the fuel fuse. Any advice gratefully recieved.
Pete
I have a 99 King also and removed the tank to get it repainted. If you just keep the ignition key off while your working on the bike(Which you will do), there's no need to remove any fuses. If you want to be safe just take the hot wire off the battery and it will do the same as removing the fuse, while working on the bike.
