Rocker Box question
Rocker Box question
I just changed out my rocker boxes on a 2004 standard and now I have a question. I followed the book and no loaded the push rods like it said. Piston at top dead center and the pushrods were spinning by hand. After I finished installing the rocker assy. the push rods didnt spin. I havent tried starting the bike yet due to darkness (want to be able to see any oil leaks). Will there be a problem when I do start the bike or is this normal? I figured it should be ok since I didn't change any adjustment. Stock push rods I believe are not adjustable. Anyone experience this before?
RE: Rocker Box question
Piston should be at TDC on the compression stroke to unload the valve springs when you install (or adjust) p-rods for that cylinder. If you can't twist the p-rods w/your fingers after the lifters bleed down I wouldn't turn the motor over till I figure out why. Are you sure you got intake/exhaust p-rods in the right places? They're different lengths.
VicW.
VicW.
Hyd lifters need to bleed down when they're compressed (or many times when RE-compressed as in this case). If it were me I wouldn't crank it up until I was sure that the p-rods of both cyls will twist w/piston at TDC COMPRESSION stroke.
BTW, on compression stroke the pistons be will pushing air out thru the spark plug holes.
VicW.
VicW.
Start it up! this is normal as 1 cylinder 's valves will be in a different position than the other ones. Unless you rotate the engine until all the valves return to TDC one ata a time you will always have tight pushrods. They are non adjustable so there are no worries .. Have fun and ride safe..Mark..
Well today I raised the back tire off the ground and put each cylinder to tdc. The push rods spun freely. I started the bike and now notice a little ticking sound. Don't remember if it was there before. Other posts I have read say a little ticking is normal. Who knows it may have been there before and I never noticed it.
