High compression pistons for 07 dyna
Old 05-26-2007 | 11:40 AM
fullthrottle1's Avatar
fullthrottle1
3rd Gear
Default High compression pistons for 07 dyna
Hello everyone trying to find a set of high compression pistons to suit my 07 dyna they will need to be 103 cubic inch and arround 10.2 to 10.5 to 1 these pistons will need to work with the stock cyclinder heads as I am having them ported. Brands,suppliers and contact details would also help as I'm in Australia the land down under.
Old 05-27-2007 | 01:01 AM
bobcowan's Avatar
bobcowan
Default RE: High compression pistons for 07 dyna
I got mine from the dealership.
Old 05-27-2007 | 02:21 PM
chopperhead2's Avatar
chopperhead2
you can use the earlier 103 stroker pistons in your 07. you just have to either buy the bigger bore cylinders or bore yours out. I don`t have any part numbers avaialble andI can`t remembe how many different sets were available but you should be able to find what your looking for. I think the flat top 103 pistons are goof for 9.5:1 with stock heads. you could always shave your heads a bit to raise the compression and run a thinner head gasket.
Old 06-03-2007 | 04:51 PM
Kingofcubes's Avatar
Kingofcubes
I have those in 107" for that stroke. Just bore your existing cylinders.PM me.
traveler
03-25-2020 11:04 PM
Lamar07
Engine Mechanical Topics
12-28-2018 03:18 PM
brad75raiders
05-02-2017 12:17 PM
drhooligan
09-10-2008 05:47 AM
Madpoodle
01-09-2007 09:01 PM
