05 springer carb questions
Old 05-26-2007 | 10:55 AM
joker2168's Avatar
joker2168
6th Gear
Default 05 springer carb questions
[align=left]So I have a couple of problems. 1st one is when my bike is warmed up and running it idles high. Not sure where I adjust this on my Carb. I think it is the screw above the spring? 2nd question is on Deceleration the bike backfires out the muffler. I did have a stage 1 kit done so I think it is running rich. Any idea how I fix that? is there a adjustment for air/fuel on the stock carb?[/align][align=left]Thanks for the help![/align]
Old 05-26-2007 | 11:58 AM
mulch63's Avatar
mulch63
Default RE: 05 springer carb questions
Look under the Do it Yourself section, Fuel...... plenty of tips there. show you how to access the mixture screw,rejet and so on.
Old 05-26-2007 | 01:38 PM
joker2168's Avatar
joker2168
6th Gear
I had a look there and I guess I was hoping I did not have to drill that plug out to stop the carb from running rich. I look at my right side tail pipe and it is black. The other tailpipe is alot cleaner. I think most of the exhust comes out the right side like 60/40. I think.
Old 05-26-2007 | 02:36 PM
mp's Avatar
mp
What "kit" do you mean? If you added a DynoJet or Yost Powertube or that kind of thing to your carb, it's going to be rich. If someone put in new jets it's going to be rich. All you need with your carb is the stock jets along with the '88-'89 1200 Sportster needle for the idle jet. The Sporty needle is a little smaller, effectively making the idle circuit a little richer. More fuel on the bottom end is what you want. The stock main jet is fine the way it is.
If a kit was added to your carb, the A/F mixture plug should be already drilled out. The idle speed can be adjusted with the screw on the outside of the carb. Don't go any lower than 900rpm on a warmed up bike.
Old 05-26-2007 | 02:40 PM
joker2168's Avatar
joker2168
6th Gear
Thanks for the info. The kit is the harley stage 1.Were is the idle screw? I can seem to see it.
Old 05-26-2007 | 09:00 PM
mp's Avatar
mp
The screw to adjust the idle speed is on the top right hand side of the carb, angled so you're looking right at the head of the screw as you peer in there. Pretty sure all CV carbs are the same. Adjust the idle speed only after the engine is at normal operating temperature.
Old 05-27-2007 | 04:47 AM
joker2168's Avatar
joker2168
6th Gear
Thanks very much!
Tileman2692
11-13-2016 07:45 PM
massparanoia
10-26-2015 09:43 AM
zakaria777
Carburetor Related
10-09-2015 08:18 PM
Rusty70
04-06-2008 05:01 PM
joker2168
05-25-2007 08:45 PM
