02 Roadking fuel problems ??????
Old 05-25-2007 | 07:15 AM
hawg02's Avatar
hawg02
Stage IV
Default 02 Roadking fuel problems ??????
Having a problems starting, bike will start then immediatley die(s), can not give gas to keep running, but itwill restart then die Things happening:
1) I DO hear fuel pump,
2) Pulled off hose out of tank to injectors and it does pump gas.
3) pulled fuel pump anyway to check sock housing and thinking of replacing pressure regulator ( but I dont believe this is problem)
4) Noticed kill switch lite (little key) is acting wierd, blinking when it should and even when it is off at times..intermittlently. pulled this component but bike will not do anything
with itpulled....not sure if this can be bypassed to check
5) fuses good
6) no apparent "cut wires"
7) fuel vent is clear
8) have disconnected battery, ICM and connections under tank and reconnected
LOST here seems as if Im missig something simple.
Old 05-27-2007 | 05:37 AM
Doc 1's Avatar
Doc 1
Default RE: 02 Roadking fuel problems ??????
Check the IAC and Throttle Position sensor for a start
Old 05-27-2007 | 06:45 AM
hawg02's Avatar
hawg02
Stage IV
thanks Doc I will
was getting nervous, no replys......thought either I was a total dumbass, or it's worse than i thought.
again thanks for the direction
AMB2710
10-11-2021 11:45 AM
Kate58
15
12-24-2017 03:31 PM
Moboy
12-20-2010 01:07 AM
sonar_chris
10-31-2008 12:08 AM
leohd
04-03-2008 01:50 AM
