2016 slim S slip on
Old 08-15-2016 | 07:02 AM
kuchyyz's Avatar
kuchyyz
Stage IV
Default 2016 slim S slip on
Hey everyone,
Not able to get a straight answer from HD on this topic that has been covered 100 times on other bikes. I've got a stock 2016 slim s with a 110 motor and I believe it comes stock with a stage 1 air cleaner. Question is I want to add a V&h 3" slip on, will I need to remap or tune the bike? I hear that cause it has the stage 1 already the ecm will do the job??
Noob to harley so sorry in advance if it's a no brainer.
Thanks
Old 08-15-2016 | 12:08 PM
nevil's Avatar
nevil
Opening up the exhaust will increase the quantity of air going through the engine.
Do you NEED to get a tuner? Probably not, according to some folks here. But a good versatile tuner would give a big boost in performance, lower the operating temp of the motor and in general make for better response and rideability. Compared to what your new bike cost, a few hundred bucks more would be a no brainer for me.
kuchyyz (08-15-2016)
Old 08-15-2016 | 07:43 PM
kuchyyz's Avatar
kuchyyz
Stage IV
Finally talked to a person over at another HD and they said the same thing. Thanks Nevil!
Old 08-15-2016 | 10:39 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Your new bike does not have a "Stage 1" on it as it sits now in stock form. What it does have is a less restrictive air cleaner but it still has the catalytic converters in the exhaust pipes. Those are the choking points for this engine. Get rid of those and replace with a free flowing exhaust/slip-ons/resonators and a fuel management device of your choice, then you'll have a "Stage 1" as you call it. The stock ECM unit has the capability to adjust the fuel ratio +/- .03% by itself which in itself will not be enough to keep the bike from running way too lean. So do some studying on which tuner set-up will work best for you.
roadrash3
Milwaukee Eight (M8)
20
08-27-2018 06:19 AM
ripto
04-23-2017 03:49 PM
TheDukester
10-04-2012 11:09 PM
captainron62
05-31-2012 08:16 AM
09 UltraFine
04-30-2009 08:49 PM
Quick Reply: 2016 slim S slip on
