Installing new pipes, need help with the grommet
I'm installing a new set of V&H pipes, I'm having great difficulty with placing the rear bracket into the grommet, it seems there's not enough room, I even use a lub to make it easier, now the grommet came out, so now I can place the grommet on the bracket, but it seems there's not enough room for the grommet and the bracket to fit in the bracket holder. I've wrestled with this for over an hour, with different variations of puttig the bracket on, seems like it's too tight. I watched the video on uTube, and they make it look easy.
Any ideas out there in Harley land?
Received 49,745 Likes
Well, had to return the Vance & Hines pipes today, called the company their inlet is only 1-3/4 " Rienhart true duals are 2" so now I need to look for something different, any suggestions? I still want a 4" or larger, could stay with Reinharts, or get something more aggressive. My Engine is a 107, level B heads, upgraded TB and injectors.
KopperTop
03-22-2009 06:36 AM
