Aftermarket End Caps for CVO Slip Ons
Old 06-23-2016 | 10:07 PM
lefty33's Avatar
lefty33
Default Aftermarket End Caps for CVO Slip Ons
Posted the following over in the Touring section without much success. Maybe they don't exist??
I've been pretty much unsuccessful in my "searching" & "googling" on this subject so will defer to the wise minds here on the forum.
I scored a set of 4" CVO slip-ons from a friend at n/c...I will make sure he does not go thirsty They came from his 2008 CVO Ultra and are generally in great shape...other than one of the end caps has the chrome starting to flake.
I plan to change out the baffles with the CVO power cores from Fullsac...probably the 2" ones as I think this will be the sound I'm going for with my stock cat-less head pipe. At the same time I'd like to replace the end caps. I prefer the look of the newer CVO end caps that have the "revolver" look. I believe they will fit as they are held on with 3 screws and the part number for the retaining ring is still the same so this tells me the diameter & the screw/bolt pattern is the same. The issue I have is the cost of these from HD is $148.99/each ($130.99 from some of the online shops)...and that's USD!! I'm in Canada so can easily add 20% to those prices.
As far as I can find, HD accessories only lists one set of end caps to fit the CVO's...better price at $149.95/pair. They look like the stock ones but problem is they are black...I would prefer chrome.
So my question is...are there aftermarket vendors that make replacement end caps to fit these 4" CVO slip-ons?
06Ultraman
Screamin Eagle CVO Models
04-15-2018 08:08 AM
imatkel
14
11-12-2016 02:50 AM
Ultrascott
08-06-2016 08:34 AM
lefty33
06-26-2016 01:51 PM
arnie54
02-01-2016 07:42 AM
Quick Reply: Aftermarket End Caps for CVO Slip Ons
