SE CV44 Tuning - Float level
Anybody have the spec for the float level for the SE CV44?
Anybody with ANY tips on carb or ignition would be GREATLY APPRECIATED.
Currently 48 low, 220 main, Idle "5" TURNS!
Need to make sure the float is right before chasing the rest around.
Runs clean and PULLS!
Plugs off white for what little color shows in 1800 miles.
I'm running
95 inch
10/1 (KB flat top, .030 milled, .030 Cometic gasket)
TW-6H Chain drive cams(TP rollers, Crane Molly's)
4 degree Advance Sprocket.
Big Boyz Cycle Street Port in Stock heads (stock size Manley valves)
Hi-4TC Ignition
SE II's Slant cut on stock headers
Just getting it broken in but WOW!
Can't hardly wait to see what it will do when properly setup.
THANKS!
I'm running
95 inch
Hi-4TC Ignition
THANKS!
