anybody installed fuelpack on 07 fatboy? do you feel electrical connections are all crowded after installing? Installed mine according to directions, connector out of ecm has the connector out of fuel pack underneath just dont really like worrying about this. Do you like the way the fuel pack is sandwiched behind battery etc. or should I worry about it. To everybody else I wouldnt advise fuelpack spend the money and time on the race tuner thanks
I had similiar space problems with my 03 Heritage. The Mustang seat compounded the problem and I had such a small space beneath the seat, there was no room for the PC III. I had to cut an opening in the rear fender above the ECM, fabricate a shallow tray in which to place the PC III and,seal and fasten the tray to the fender. I ran the wiring harness under the fender, fastened with harness clamps and then connected to the ECM. Every thing fit perfectly but it was a lot of work. A few hour job turned into a two day job.
