Exhaust heat wrap ?
Exhaust heat wrap ?
Like to get some feedback on exhaust heat wrap...
I've seen other post saying the pipes were ran hotter on the outside I could see maybe on the inside, but assumed they would be cooler to the touch on the outside is this so ?
Also, any performance differences ?
Any problems with it ?
Yeah this^^^^^^^^^^^.
But YOUR bike, your pipe, your money. Do what you like.
Good luck.
YB
Header wrap in my personal experience is only good for prolonging starter life on a V8 with headers routed near the starter. Even then header wrap does not retain nearly enough heat to be considered effective. That's where custom made heat shields came into play on some of the hot rods I've built when I got tired of replacing starters. On some yes the wrap did promote rusting as you may trap water moisture and corrosive elements to the headers. If heat from the pipes is an issue go faster and if you have any goofy fairings blocking air from flowing that will cause a heat issue as well.
