V&H exhaust popping
V&H exhaust popping
Hi there,
I put V&H Short Shots on my 2014 Street Bob and now it pops when I decelerate. I have taken to avoiding compression by engaging the clutch when I let off the gas, which helps a bit, but I would like to fix the issue.
I purchased the quiet baffles (standards are installed) because I read somewhere that the back ptessure might fix the popping. I have not yet installed them.
My concern is the health of the engine. I am heading to sturgis this year from SF and I want to make sure all is right before I take any long hot trips. Does changing the baffles pose any real risk to the engine? Pressure and all?
Sorry, very much a noob here.
The standard remedy is to correct decel enleanment and also prevent the reversion of air in to the exhaust system. XIED's typically can add enough extra fuel off throttle to reduce the decel popping. Obviously a flash tuner like the Power Vision can give you much more refined control over decel enleanment. But your riding style, IE not quite letting off the throttle, an improperly adjusted throttle, or a mal-adjusted TPS sensor can cause the same result of increased decel popping.
A remedy to help prevent the reversion of fresh air in to the exhaust system is to add DK Custom Products Thunder Torque Inserts. The TTI's are designed to increase the velocity of the exhaust gas exiting the system. The 'W' model is a patented design that creates a venturi effect due to its shape, the 'cup' side of the TTI facing the end of the pipe helps prevent air reversion back in to the exhaust which will help minimize the decel popping while increasing low and mid range torque.
Beetroot McKinnley, while this video is of a Sportster you will be able to hear the differences in the Short Shots with and without Thunder Torque Inserts:
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
irlm1
30
04-22-2023 06:52 PM
user 8382390
10-08-2018 07:50 PM
