Do I have to rejet again?
RE: Do I have to rejet again?
You need a rejet, something in the area of a 46 low and a 190 high jet would get you close. Don't drill the slide, it causes other problems with opening too fast under certainconditions and causes the mixture to lean out which will cause surging.
Adjusting the idle screw wouldn't give you enough.
If you were running the stock air cleaner before you installed the big sucker, then yes...rejet.
The big sucker will allow considerably more air into the carb / engine than the stock air cleaner. Without adding more fuel to this air, your engine will be running lean.
CSS_FXD
08-17-2014 01:56 AM
