Down to 3 now to Decide
Not a lot of guys in my area running 2 into 1 exhausts on touring bikes. So I've narrowed it down to 3 exhaust systems in my price range. Performance should be close on all 3 I imagine. I'm looking for first hand/ear input on volume difference of the 3. Yes, I want the loudest of the 3, but do put build quality and performance up there to.
: Bike is a 2011 Road Glide. Will be getting Fuel Moto micro tuner and Arlen Ness Big Sucker stage 1 w/ cover at the same time as exhaust.
V&H Pro-Pipe Black with Standard baffle
Rush 2 into 1 Bagger Exhaust Black 2.5 inch Baffle (not the wrath system)
Cobra Power Pro 2 into 1 Black
Both the V&H and Rush can be had for a hair above $620 while the Cobra is all over ebay for around $520.
Any help/opinions would be awesome
Previous exhaust was stock head pipe with CFR knock offs. Sounded good but want more volume and performance.
Only future mod maybe cams/head work next winter......
You can get the V&H pro pipe on ebay for $582.97 and free shipping http://www.ebay.com/itm/Vance-Hines-...pVsV2O&vxp=mtr or here same price http://www.ebay.com/itm/Vance-Hines-...cAAOSwiCRUk0Qo
If you go with the pro pipe and want it louder go with the competition baffle.
From what I read the Wrath would not run well with my stock compression ratio, just going stage 1 with no plans for comp bump or cam.
Everything I've read has the Rush Wrath being used on bigger builds, plus at $150 dollars more then the regular Rush Bagger system you're getting into thunder header and D&D type money. More then the Dragula form Drago.
Any body heard or seen the 2 into 1 from Cobra. All the pipes I've ever seen from Cobra look top notch.
The pipe has to be Black for my application.
Out of these 3 pipes -
V&H seems to be most popular
Rush is ceramic coated inside and out
Cobra can't find any rear info / sound bytes.
Anybody heard the pro-pipe with standard baffle next to the Rush 2 - 1 with 2.5 inch baffle.
