Exhaust gasket install?
Hey board bros ... any of you have any ideas of how to install new HD conical style type exhaust gaskets?
They seem fragile and easily bendable.
Right now, I can get one to start, but not able to get it seated without it starting to bend. I stop before I end up destroying it.
Thanks.
Thanks.
And make sure you have removed all of the old ones. They can be so smushed that they look like they are part of the exhaust manifold. Make sure you get all of the old one out.
Then go get new exhaust flange nuts. Look into the new threads and you'll see that there is a crush part in the thread of the new nuts that is there to hold the torque.
You'll still have to re-torque after several full heat cycles and you'll notice when you do this that between the crush gaskets seating in and the heat cycles, the nuts will move tighter after being retorqued again after the heat cycles. Sounds unnecessary but it will seal the exhaust better to the flange. No air leaks.
Thanks for the tips guys ... and videos.
I found that there is an actual tool made to do it:
https://www.denniskirk.com/jims/exha...prd/283277.sku
Once I get it all together, I'm hoping I don't have any leaks.
Thanks for all the tips and help guys!
