carb fine tuning - rich
Old 05-03-2007 | 01:41 PM
Jip's Avatar
Jip
Default carb fine tuning - rich
I'mrunning slightly rich, with 46 jet, 3 shims (0.017) and 2 1/2 turns. It pops a bit when cold, plugs areblacker than brown. What would you do, leave as is, remove 1 shim or go to 2 turns?
Old 05-03-2007 | 02:17 PM
JakeSabre's Avatar
JakeSabre
Default RE: carb fine tuning - rich
If the plugs are black after idling for a minute, screw the idle adjust in.
Run the bike on a deserted road, hold the throttle open 1/2 way in 3rd or 4th gear, when safe to do, roll off the throttle, hit the kill switch, coast to a stop, and read the plugs. If they are not light brown, drop the needle.
Old 05-03-2007 | 04:51 PM
Jip's Avatar
Jip
thanks, so check if its an idling problem first, turn in screw if needed and then check again, and ifits still too richthen remove a shim
Old 05-04-2007 | 11:36 AM
ohiomotoxer's Avatar
ohiomotoxer
Rich where?
What throttle position?
0~1/4 = fuel screw. slow jet.
1/4 ~3/4 = needle clip position.
3/4 to WOT = main jet.
When doinga throttle chop use NEW plugs, look at the base ring to determine AFR.
http://www.dragstuff.com/techarticle...ead-plugs.html
ORIGINAL: Jip
dirtfarmer
01-19-2018 07:47 PM
Fblo1690
EVO
10-11-2017 08:13 PM
ryamatt
07-07-2013 09:14 PM
hog85
EVO
18
08-26-2011 09:09 AM
RLJ676
Carburetor Related
18
05-04-2011 10:08 PM
