Discoloration of Rineharts End Caps
After having Rineharts installed on my 2008 Ultra I encountered what seems to be a common occurrence of one of the end caps changing to a purple color. As per the normal course the HD stealership informed me after the warranty was up that I could have sent them in for replacement. Going forward I was told that if I switch them around the colours would eventually match up. After removing them I found that the discoloured side had 16 hours drilled counter sunk into it and the other only 2. Does anyone know if this is the correct configuration?
dchoran
09-29-2006 11:02 PM
