cam chain adjuster(again)
RE: cam chain adjuster(again)
What problem?????
If you have 25k milesor more, then you should maybe consider inspecting them....
Not at 8 months and prolly no more than 10k miles.....
Stuff wears out, sometimes prematurely, sometimes it has longevity.....
They are nylon shoes, being pressed against a roller chain assy....
Same type of assembly as the Primary chain and adjuster shoe, just a bit smaller...
Sorry, but if it worries you that much, change out to Gear Driven cams.....
I have heard from one or two knowledgeable sources that they are seeing good amounts of wear on the new hydraulic tensioner set ups.
Thanks,
VicW.
it's a shame HD didn't use a better grade of plastic on the tensioners. there are grades that are self lubricating that never wear out. my neighbor works at a printing company and similar tensioners are used there and they never wear out running 24 hours a day. but save a dollar on 25,000 bikes they saved $25K.
