New pipes
So I got the new pipes on and seems to run fine although I haven't gone very far. I can't seem to get the front pipe 100% sealed. The rear is fine but the front won't quite seal around the upper nut area (10 or 11 o'clock position). I've used 2 different gasket sets with the same result in exactly the same spot. It's not much of a leak, but I'm just wondering how much is too much?
Thanks in advance, Matt.
P.S. Did I mention the pipes are from a 2012, 103 Wide Glide, and mines an 06 Softy.
Damn. I was afraid of that! My local Harley 'experts' told me they should bolt up the same at motor, it's just mounting bracket that would be very different. Also I modified the Dyna bracket so it's mounted to the trans instead of the frame. Would that also be a problem on a Softail? I really do like these pipes better, they seem to have better low range torque than the big radius, but I may have to change back and accept defeat!! Thank for the replies, Matt.
