Stock head pipe 2-1??? Can it be done
I have a Supertrapp 2-into-1 and the point where the two pipes come together is a lot bigger than just one pipe! So that's the 'approved' way of doing it, although in the distant past Harley used the same size of pipe for their 2-into-1. On a modern motor, which gives significantly more performance than those older bikes, I suspect your idea may indeed prove restrictive. Now a system like my Supertrapp.......
yep yep I knew at best it would be cheating i was just looking to see while I removed the cat if I could get anymore outta it till I did a full exhaust this winter.
Thanks for the reply I was beginning to think I was the only one that could see the post. I realize it was far fetched but thought maybe someone did something similar and would chime in.
Squadboss36
Exhaust System Topics
07-28-2015 12:01 AM
