Rinehart problem and help please...
Old 04-21-2007, 06:39 PM
jrudicel's Avatar
jrudicel
jrudicel is offline
Default Rinehart problem and help please...
Got the 06 StreetGlide with the Rinehart new style true duals. Got a "rattle" on the rear cylinder pipe somewhere. When idleing and shaking, sounds like a metal knocking rattling sound. Asked my dealer about it(although I did the install) and they said it is probably the baffle rattling. Anyone heard of this or know what exactly is involved in checking this? Kinda annoying at times... Thinkin
of just doing a 2-1 FatCat, TH, or Bassani and be done with them! lol
Old 04-21-2007, 07:22 PM
OneBlackFly's Avatar
OneBlackFly
OneBlackFly is offline
Default RE: Rinehart problem and help please...
Don't laugh now. I had the same problem and Rinehart told me to pull the baffles, hit them w/ a soft hammer to egg-shape them (but not too much) and put them back in. BTW - it works.
Old 04-21-2007, 08:19 PM
jrudicel's Avatar
jrudicel
jrudicel is offline
Not laughing... I am a machinist and figured it might be a smaller diameter baffle in a larger body rattling. You were in a sense, making the baffle bigger around at the aidest point so it didnt rattle. Will have to try that. Mine seems to be in the rear cylinder pipe. Only at idle.. When it is "clanging" and rattling, if I put my foot under the clamp where the slip on goes on the head pipes and push against it slightly, it quits.. Sound like yours? I assume pulling the baffle wasnt hard. Will have to go out and look at mine and give it a shot...or a smack as you said!
Old 04-21-2007, 09:08 PM
OneBlackFly
Mine rattle was inthe front one only and only a small smack did the trick. Baffle pull out easily.
Old 04-21-2007, 11:53 PM
chriscalabro's Avatar
chriscalabro
chriscalabro is offline
I had the same issue. In my case I found the the noise could be eliminated by using a tie wrap to tighten up the muffler to the rubber mount. I used two per side and it stopped the noise.
Old 04-22-2007, 11:11 AM
vernh59's Avatar
vernh59
vernh59 is offline
Make sure the rear pipe isn't rattling against the primary cover. There is very little clearance between the two.
North Star
09-07-2018 11:43 AM
jokenroll
EVO
10-16-2012 08:20 AM
Crushrus
08-22-2011 11:12 PM
UltraKla$$ic
08-16-2010 09:49 AM
MarkM
06-30-2009 09:39 PM
Quick Reply: Rinehart problem and help please...
