2014 header pipe replacement, what gasket?
Okay, I bought the jackpot 2-1-2 header for my bike. The bike only has 1300 miles on it, but I think the gaskets are shot or at least mashed pretty good. Should I replace them with stock Harley gaskets or order the spiral wound gaskets from fuel Moto? Also the cross pipe seems to have a gasket on it where it attaches to the header. Is that correct?
Thanks
Thanks
Sorry, I was not very clear. I just bought a new head pipe to install myself. When I removed the stock one you could see that the gasket had been smashed pretty good when they installed the original. I heard people say to use the original one that was in there. This one just seems pretty messed up and so I thought I would put new ones in.
I had kind of given up and figured I would have to finish his project next weekend after I pick up the gaskets. So I started putting the old header into the box the new one came in and saw a sheet of paper at the bottom. That happen to be instructions and a set of gaskets stapled to it. What turned into trouble some installation went smooth as silk once I had those everything just fit perfectly.
2003flhtci
Exhaust System Topics
03-28-2009 08:38 PM
