Is it worth changing my Pro Pipe to Bassani?
Old 01-18-2015 | 08:42 AM
Herksuper's Avatar
Herksuper
Default Is it worth changing my Pro Pipe to Bassani?
So I'll be doing a cam change when I get home and I currently have a V&H Pro Pipe installed. Is it worth the extra $$$ to install a Bassani or should I keep my current exhaust? I've modified the stock baffle by cutting off the entire "end cap" that closes it off and installed torque cones...been running that for a while. Just don't wanna give up anything I can possibly gain by leaving the Pro Pipe on if there is a better 2-1.
Old 01-18-2015 | 10:42 AM
cdonis's Avatar
cdonis
Fatcat if I were to change the pipe. But your current pipe will probably be fine. A proper dyno will be more beneficial than changing the pipe after your cam upgrade.
Old 01-18-2015 | 01:12 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
D&D Fatcat is what I'd go to. Better chrome, better fit, better performance.
Old 01-18-2015 | 11:41 PM
Herksuper's Avatar
Herksuper
Thanks for the opinions, but I really don't like the look of the D&D's muffler. There is a set of Bassani's that I can get a hold of for a pretty heavy discount...just don't know if it's worth the extra coin to swap my 2-1 for another 2-1.
Old 01-18-2015 | 11:48 PM
FLS103's Avatar
FLS103
Take the money you were thinking about spending on new pipes and put it toward some headwork...I assume you were getting a tune anyway after the cams
Old 01-19-2015 | 10:26 AM
MSP Dan's Avatar
MSP Dan
^^What he said. Over the years, I've heard more than a few respected dyno tuners say something like "the difference between various quality 2 into 1 pipes isn't a lot when it comes to numbers. Find one that you like the look and the sound of and run it."
Old 01-21-2015 | 04:34 PM
dfwhockey17's Avatar
dfwhockey17
I would take a Bassani system over a V&H system every time. Better fit/finish, sound and performance IMO.
Old 01-23-2015 | 02:37 AM
slyedog's Avatar
slyedog
Unless you want looks ,which I personally don't care for the bassani pipes, performance wise you will notice nothing as the pro pipe is a well designed pipe. You may gain or possibly lose such a small margin it's not worth the time. There is a comp baffle you can get for propipe. May lose slightest bit of low end but I would verify with V&H.
Old 01-23-2015 | 11:34 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Plus 10
Definitely good advice there. For the $800 a good set of heads will give 5:1 on your return..
That is with the cam upgrade your already doing...
Old 01-24-2015 | 05:47 AM
Herksuper's Avatar
Herksuper
Thanks fellas, I emailed Bassani and they said the gain (if any) would be negligible, and only on paper. I'm not looking into head work, just a straight bolt on. So I reckon I'll get a couple of other doodads and call it good. Can't wait to get these cams installed and see what I get on they dyno rack. Thanks again.
Jackpoticorn
01-04-2016 01:16 PM
crewchief25
05-16-2011 09:10 PM
HFS
01-27-2011 07:28 AM
RhinoTuff
15
04-15-2008 07:55 PM
JimmySG
11-04-2007 07:53 PM
Quick Reply: Is it worth changing my Pro Pipe to Bassani?
