37g clearance ,compression ???
RE: 37g clearance ,compression ???
I can not tell you the awnser for sure on that cam. I can tell you that you can clay your pistons but that involves putting moter to geather then dissassambling then reassembling again or do like I did as sometimes 570 work w/stock reliefs and sometimes not and went ahead and got reliefs inlarged so I didn't have to worry about it. I tend to thank they will work also but have you called Andrews and talked to them? My partner talked to them several times and they were very helpfull.
