Header and Torque
Hell no
You don't say what pipe you have now, so I'll assume you put the mufflers on the stock exhaust with the catalytic converters in place. If so, you will need to tune the fuel/air mix for the new pipe. At the very least this means a download. The more expensive but better option is to get it tuned using a tuner like the super pro tuner, TTS, Power Vision, etc. As for the pipe. The Fullsac DX is an excellent pipe for torque. As long as your tune is good you should pick up a couple lbs./ft.
I am interested in the V&H Power Duals but these Fullsac DX pipes are looking better and use the stock heat shields.
Any updates on this thread?
JCBGlide
2014-2023 Touring Models
03-26-2019 06:14 AM
KumaRide
09-23-2016 09:28 PM
JC0311
04-20-2014 11:43 AM
