Exhaust Torque Question
Old 10-07-2014 | 06:06 PM
kcsteve's Avatar
kcsteve
Default Exhaust Torque Question
I have a 2014 Heritage Softail. I had the dealer install V & H Straight Shot
slip on. Since the install I have been getting a lot of pop on decel. I have 22 questions.
First what should the torque be on the clamp that hols the muffler to the header pipe?
2nd Is there some kind of gasket at that location.
This is my first experience with slip ons so I assume there must be some kind of gasket.
I put a torque wrench on the nut and it is 15 ft lb is that right.
And yes a service manual is on my list to purchase
Old 10-07-2014 | 06:10 PM
gchristopher9's Avatar
gchristopher9
I had a ton of decel pop with my straightshot slip ons on my 2013 deluxe. Checked head bolts and put some high temp silicon between the muffler and headpipe with no improvement. Only way I was able to get rid of it was a tuner.
Old 10-07-2014 | 07:01 PM
qtrracer's Avatar
qtrracer
I am waiting for the other 20 questions
Old 10-07-2014 | 08:49 PM
O-Town D's Avatar
O-Town D
OP, I don't have a Heritage but my FB slip-ons don't use any gasket - they just slide right onto the header pipe and the clamp seals/secures it in place. Your muff clamp is the same as mine, and torque spec is 38-43 ft-lbs. Also, you may want to check the header pipe flange nuts at the head - they have a tendency of loosening up after a while and causing decel pop. Hope that helps.
Old 10-07-2014 | 09:56 PM
kcsteve's Avatar
kcsteve
Thanks O-Town.
That helps, I will see if I can come up with the exact torque specs.
rsscoggins
05-28-2014 06:47 PM
saltlick
05-24-2014 01:23 PM
R_W_B
10-24-2010 06:47 PM
WillieD
02-10-2009 10:18 AM
rickoshay45
11-08-2008 04:41 PM
