POR 15 tank sealer
Received 4,361 Likes
Great Stuff, check it out:
http://www.caswellplating.com/restor...nk-sealer.html
I haven't used POR 15, so I can't compare. I did use Caswell Tank Sealer, and it works great. Used it to line a fiberglass BSA tank about 5 years ago, and no problems since. Fiberglass dissolves with the new ethanol fuels.
Thank you for the reply but I am not impressed with Caswell.
I put it in the Taiwanese aftermarket tanks I have and 2 years later it is flaking out like you wouldn't believe.
A few things to watch out for.
1. if you get this stuff on your paint, it will mess it up!!!! I tried to be careful, but still got some on my paint. Mask off the entire outside of the tank. Maybe 2-3 layers of masking/painters tape.....
2. I had a fat bob or fat boy, some kind of fat tank :-) I think fat bob. It was a super wide, two-piece tank. Anyway, each tank, right and left, had tubes with elbows coming out of the bottom. It was a cross over tube, and another one that was the fuel line going to carb..... anyway, Those little tubes filled up and it hardened!! I had to cut them off so they no longer had 90 degree bends, and drill them out..... all in all it worked out ok, but If I had shoved a wire or something up those tubes while the last stage was drying or curing, it would have been better.....
Those are just my two suggestions.... The stuff works great though. I went from having rusty trashy tanks, to takes that looked like a newly sealed and painted garage floor :-) No more trash in the carb
I used it on my 98 Heritage.... I KEPT getting trash in my carb and messing up my ride. You could see the trash/rush in my tanks. I finally bit the bullet and ordered the 3 step POR 15 sealing process.... it worked, no more problems.
How long ago did you do this?
Has it held up over time?
