How to: Replace broken shifter pawl spring.
Old 07-19-2023, 08:20 PM
Spanners39's Avatar
Spanners39
Spanners39 is online now
Originally Posted by razor ray
Don't do it the seal from the trans will be broken and it will leak trans fluid from then on untill you pull your inner primary and change the seal
Nonsense...
  #62
Old 07-19-2023, 08:23 PM
Spanners39's Avatar
Spanners39
Originally Posted by bz78pl
Originally Posted by Spanners39
You don't need to do 4/5ths of what you show here.
Leave the primary side of the bike alone completely except for remove the shift lever from the splines and flicking the circlip off the shaft (you will need a new circlip and preferably the seal too.
Pull the top off the tranny and remove the shifter assembly.
Remove the clutch mechanism cover and the trap door assembly (Use a puller or hide Mallet and replace the bearings before reassembly)
You can now wiggle the countershaft out of the way just enough to remove the shifter shaft assembly and get a magnet in there to remove any missing pieces.
Reassemble in reverse order but fit the seal and circlip before replacing the countershaft.
Its a fiddle but will save you 3-4 hours and a shitload of cash.
Would I be able to carry this process out on my 2007 Road King ?
I really want to avoid playing with the primary and other bits and pieces. My only question is, how do you replace the shifter pawl seal (if needed) without removing the primary case...?
On its own and not part of the shifter shaft job? Easier to pull the primary in that case. Twin Cams are dead easy to work on.
  #63
Old 07-20-2023, 03:48 AM
bz78pl's Avatar
bz78pl
bz78pl is offline
6th Gear
Thanks, I'll have to give it a go and see what happens. There are not too many HD mechanics around, so I'll have to do it on my own. Given that I'm not a mechanic, it will be a major challege... fingers crossed
I'll stay in touch.
  #64
Old 07-20-2023, 12:12 PM
bz78pl's Avatar
bz78pl
bz78pl is offline
6th Gear
I opened the top of the tranny first and couldn't see any problem with the spirings. It finally turned out that the shifter pawl shaft's rivet at the bottom is cracked, is it even posisble ? Everyone seems to have problems with the springs only...
  #65
Old 07-22-2023, 04:27 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,865 Likes on 1,263 Posts
LMAO Ok You did see it
Good to see ya Sir
Spanners39 (07-22-2023)
  #66
Old 07-22-2023, 05:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,411 Likes on 5,011 Posts
This thread is way off track...
This OP was asking about replacing the shifter pawl spring in a 5 speed transmission.
The latest poster is asking about working on a 6 speed transmission on a Twin Cam.
@bz78pl Start a new thread, give details of bike, and what the issues are.
  #67
Old 07-22-2023, 05:56 PM
Spanners39's Avatar
Spanners39
Chill, all is one and one is all Grasshopper...
  #68
Old 07-22-2023, 06:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Nonsense.
  #69
Old 07-23-2023, 05:47 PM
Spanners39's Avatar
Spanners39
Nonsense.
I see we need to work on you young man...next thing you know, people will be saying that Twin Cams and M8's aren't real Harleys...
  #70
Old 07-23-2023, 07:47 PM
Mountainkowboy's Avatar
Mountainkowboy
Mountainkowboy is offline
Received 1,010 Likes on 544 Posts
Originally Posted by spanners39
i see we need to work on you young man...next thing you know, people will be saying that twin cams and m8's aren't real harleys... :d
Spanners39 (07-23-2023)
Dynafrom818
04-08-2019 04:31 PM
Gibbs03EG
08-13-2014 02:31 PM
Twizted
13
02-04-2011 12:48 AM
RidemyEVO
01-24-2010 11:45 AM
Iangp
06-21-2006 08:35 AM
Quick Reply: How to: Replace broken shifter pawl spring.
