Sheared Motor Mount bolts
Old 09-25-2014, 07:52 AM
johnod's Avatar
johnod
johnod is offline
Originally Posted by nyokie
talking about 47159-79A the front engine bracket? the tab that goes from motor mount and motor? It should be flat, pretty bizarre if that was bent, wrecked maybe?
Yes that's the part, looked more like a factory flaw to me, but of course I don't know.
Any one know if the stabilizer tab on that mount is supposed to be centered or offset?
  #32
Old 10-25-2014, 03:32 PM
johnod's Avatar
johnod
johnod is offline
Well winter is headed to these parts, and riding is coming to an end soon.
So I thought I'd update this, in case anyone is still interested.
Since my alignment, and new motor mount I've done 700 mi, so far so good, still tight, and not broken.
Maybe that was the problem.
Hope so.
  #33
Old 10-25-2014, 06:09 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,866 Likes on 1,264 Posts
Well I certainly have been. I have worked through a few real problems with mine. Not this but it's good to hear ya may have made some head way with it.
Good deal
WP
  #34
Old 10-25-2014, 08:05 PM
johnod's Avatar
johnod
johnod is offline
I hope I have, 700mi is not a long enough test, but like I said winter is on the way, so I thought I'd update, for Old-Evo in particular.
  #35
Old 10-26-2014, 01:45 PM
Old-Evo's Avatar
Old-Evo
Old-Evo is offline
Thanks for the update. I'm going to see my Indy next Saturday to talk to him more about this issue, and a rear belt replacement that I'm due to get done.
  #36
Old 10-28-2014, 12:47 PM
johnod's Avatar
johnod
johnod is offline
Just shy of 900mi now, starting to feel good about this.
  #37
Old 10-28-2014, 04:19 PM
miacycles's Avatar
miacycles
miacycles is offline
Fine thread bolts hold tighter and tend to loosen up less often. You obviously have something wrong up there. Perhaps alignment, front motor mount too tight, front motor
mount twisted, perhaps the wrong front motor mount or something wrong with the top mount allowing the engine to twist. We use the stiffer Buell front isolator in our touring bikes, perhaps that might help ?? Check the alignment yourself according to the manual.
John
  #38
Old 10-28-2014, 05:06 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Hopefully you see this John. I looked for that Buell part number and did not see it. Is it fit the evo sporty motor or is it the Rotax?
Thanks,
Tom
  #39
Old 10-28-2014, 05:21 PM
johnod's Avatar
johnod
johnod is offline
John
I think you missed some of the posts, I did some of those things, and was trying to state that I may have fixed the issue.
This was mainly for the other guy with the same problem.
Thanks for the Buell tip though.
As far as the Buell part number goes maybe check over at
http://www.badweatherbikers.com/cgib....cgi?pg=topics
  #40
Old 10-28-2014, 05:30 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Hey TV, read this, but remember it's from the Touring Forum so there is a lot of ignorance. (Not trying to contradict John)
https://www.hdforums.com/forum/touri...ing-bikes.html
Quick Reply: Sheared Motor Mount bolts
